Guys, after updating my router bgp sessions are no longer identified by Librenms.
Is there any tips to solve this issue?
They changed the MIBs and/or the SNMP replies. And BGP support right now is not optimal. I am working on it right now (on CloudEngine and Campus family). I’ll contact you to test it on your NE.
OK, thanks for the help. Much success for this extraordinary tool!
Hello guys, anything new in this issue?
Hi @mrmarcio31rs
The code is already posted here.
You can test it with this command :
./scripts/github-apply 11054
Let me know the results.
Thanx
:2264: trailing whitespace.
:2265: trailing whitespace.
– Description: HUAWEI-BGP-VPN-MIB , this Mib module for management
:2267: trailing whitespace.
– Reference: This MIB was extracted from RFC 4271
:2275: trailing whitespace.
:2280: trailing whitespace.
FROM HUAWEI-MIB
Checking patch includes/discovery/bgp-peers.inc.php…
error: while searching for:
if (!empty($af_data)) {
$af_list = build_cbgp_peers($device, $peer, $af_data, $peer2);
if ($device[‘os’] == ‘vrp’) {
d_echo(“VRP:”);
$af_data = snmpwalk_cache_oid($device, ‘hwBgpPeers’, $af_data, ‘HUAWEI-BGP-VPN-MIB’);
if ($device['os_group'] === 'brocade') {
// Brocade doesn't return MP-BGP SAFIs in the BGP4V2-MIB data, so it only displays the unicast SAFI
error: patch failed: includes/discovery/bgp-peers.inc.php:144
error: includes/discovery/bgp-peers.inc.php: patch does not apply
Checking patch includes/discovery/functions.inc.php…
Hunk #1 succeeded at 1213 (offset -18 lines).
Checking patch includes/polling/bgp-peers.inc.php…
Hunk #1 succeeded at 395 (offset -21 lines).
Checking patch mibs/huawei/HUAWEI-BGP-VPN-MIB…
Hi @mrmarcio31rs
Was your LibreNMS instance up to date ?
Please run :
./validate.php
./daily.php
./validate.php
Hi @PipoCanaja
root@cqnet-librenms:/home/camaquanet# su - librenms
$ ./validate.php
| LibreNMS | 1.60 |
| DB Schema | 2019_12_28_180000_add_overwrite_ip_to_devices (156) |
| PHP | 7.2.24-0ubuntu0.18.04.2 |
| MySQL | 10.1.43-MariaDB-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.3
$ ./daily.php
-su: 5: ./daily.php: Permission denied
$ ./scripts/github-apply 11054
:2263: trailing whitespace.
:2266: trailing whitespace.
:2274: trailing whitespace.
:2279: trailing whitespace.
FROM HUAWEI-MIB
Applied patch includes/discovery/bgp-peers.inc.php cleanly.
Applied patch includes/discovery/functions.inc.php cleanly.
Applied patch includes/polling/bgp-peers.inc.php cleanly.
Applied patch mibs/huawei/HUAWEI-BGP-VPN-MIB cleanly.
warning: squelched 344 whitespace errors
warning: 349 lines add whitespace errors.
OK. It looks better now. The patch is applied. Let me know if you have a better display of the BGP peers.
Concerning this :
$ ./daily.php
This is not expected. You seems to have a right issue here. Please check the permissions and owner here.
Hello @PipoCanaja
success! everything ok with the bgp pairs now. Thanks for everything!
All right. The PR will be merged in a few days, weeks, as soon as I can collect the test data (for regression tests). When it is merged, you’ll have an error in your daily.sh update (it will complain the files are modified). You’ll have to revert the files to their original state and then daily.sh will run smoothly.
Hello @PipoCanaja thank you for your work. We own HUAWEI40E-MK2B too and we can see peers and status of them, but what we missing is number of prefixes. Updates are working, but number of prefixes not. Question is why, because we alredy have that informations in discovery run in SNMP['/usr/bin/snmpbulkwalk' '-v2c' '-c' 'COMMUNITY' '-OQUs' '-m' 'HUAWEI-BGP-VPN-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/huawei' '-t' '5' 'udp:HOSTNAME:161' 'hwBgpPeers'] like this
hwBgpPeerPrefixRcvCounter.0.ipv4.unicast.ipv4."*" = 806549
hwBgpPeerPrefixRcvCounter.0.ipv4.unicast.ipv4."*" = 386
hwBgpPeerPrefixRcvCounter.0.ipv4.unicast.ipv4."*" = 73662
hwBgpPeerPrefixRcvCounter.0.ipv4.unicast.ipv4."*" = 2
hwBgpPeerPrefixRcvCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:11" = 33004
hwBgpPeerPrefixRcvCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:12" = 33003
hwBgpPeerPrefixRcvCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:02:38" = 2
hwBgpPeerPrefixRcvCounter.0.ipv6.unicast.ipv6."2a:01:03:90:06:66:04:25:00:00:00:00:00:00:00:01" = 85695
hwBgpPeerPrefixRcvCounter.0.ipv6.unicast.ipv6."2a:03:27:60:00:01:00:01:00:00:00:00:00:00:00:02" = 3
hwBgpPeerPrefixActiveCounter.0.ipv4.unicast.ipv4."*" = 733001
hwBgpPeerPrefixActiveCounter.0.ipv4.unicast.ipv4."*" = 385
hwBgpPeerPrefixActiveCounter.0.ipv4.unicast.ipv4."*" = 2
hwBgpPeerPrefixActiveCounter.0.ipv4.unicast.ipv4."*" = 73548
hwBgpPeerPrefixActiveCounter.0.ipv4.unicast.ipv4."*" = 0
hwBgpPeerPrefixActiveCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:11" = 32986
hwBgpPeerPrefixActiveCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:12" = 0
hwBgpPeerPrefixActiveCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:02:38" = 0
hwBgpPeerPrefixActiveCounter.0.ipv6.unicast.ipv6."2a:01:03:90:06:66:04:25:00:00:00:00:00:00:00:01" = 52392
hwBgpPeerPrefixActiveCounter.0.ipv6.unicast.ipv6."2a:03:27:60:00:01:00:01:00:00:00:00:00:00:00:02" = 2
hwBgpPeerPrefixAdvCounter.0.ipv4.unicast.ipv4."*" = 8
hwBgpPeerPrefixAdvCounter.0.ipv4.unicast.ipv4."*" = 2
hwBgpPeerPrefixAdvCounter.0.ipv4.unicast.ipv4."*" = 1
hwBgpPeerPrefixAdvCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:11" = 1
hwBgpPeerPrefixAdvCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:12" = 1
hwBgpPeerPrefixAdvCounter.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:02:38" = 1
hwBgpPeerPrefixAdvCounter.0.ipv6.unicast.ipv6."2a:01:03:90:06:66:04:25:00:00:00:00:00:00:00:01" = 1
hwBgpPeerPrefixAdvCounter.0.ipv6.unicast.ipv6."2a:03:27:60:00:01:00:01:00:00:00:00:00:00:00:02" = 2
And in SQL I can see only 0 values in Prefixes.
SQL[INSERT IGNORE INTO `bgpPeers_cbgp` (`device_id`,`bgpPeerIdentifier`,`afi`,`safi`,`context_name`,`AcceptedPrefixes`,`DeniedPrefixes`,`PrefixAdminLimit`,`PrefixThreshold`,`PrefixClearThreshold`,`AdvertisedPrefixes`,`SuppressedPrefixes`,`WithdrawnPrefixes`,`AcceptedPrefixes_delta`,`AcceptedPrefixes_prev`,`DeniedPrefixes_delta`,`DeniedPrefixes_prev`,`AdvertisedPrefixes_delta`,`AdvertisedPrefixes_prev`,`SuppressedPrefixes_delta`,`SuppressedPrefixes_prev`,`WithdrawnPrefixes_delta`,`WithdrawnPrefixes_prev`) VALUES (:device_id,:bgpPeerIdentifier,:afi,:safi,:context_name,:AcceptedPrefixes,:DeniedPrefixes,:PrefixAdminLimit,:PrefixThreshold,:PrefixClearThreshold,:AdvertisedPrefixes,:SuppressedPrefixes,:WithdrawnPrefixes,:AcceptedPrefixes_delta,:AcceptedPrefixes_prev,:DeniedPrefixes_delta,:DeniedPrefixes_prev,:AdvertisedPrefixes_delta,:AdvertisedPrefixes_prev,:SuppressedPrefixes_delta,:SuppressedPrefixes_prev,:WithdrawnPrefixes_delta,:WithdrawnPrefixes_prev)
{"device_id":470,"bgpPeerIdentifier":"86.110.242.90","afi":"ipv4","safi":"unicast","context_name":"","AcceptedPrefixes":0,"DeniedPrefixes":0,"PrefixAdminLimit":0,"PrefixThreshold":0,"PrefixClearThreshold":0,"AdvertisedPrefixes":0,"SuppressedPrefixes":0,"WithdrawnPrefixes":0,"AcceptedPrefixes_delta":0,"AcceptedPrefixes_prev":0,"DeniedPrefixes_delta":0,"DeniedPrefixes_prev":0,"AdvertisedPrefixes_delta":0,"AdvertisedPrefixes_prev":0,"SuppressedPrefixes_delta":0,"SuppressedPrefixes_prev":0,"WithdrawnPrefixes_delta":0,"WithdrawnPrefixes_prev":0}
there is also missing info about Family but afi ans safi are added in sql so I don’t understand why it’s not possible to view it in UI. Also I don’t know if poller is working fine because I can see un UI State of some peers loke stop or nothing but in snmpwalk are all in start admin status
hwBgpPeerAdminStatus.0.ipv4.unicast.ipv4."*" = start
hwBgpPeerAdminStatus.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:11" = start
hwBgpPeerAdminStatus.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:00:12" = start
hwBgpPeerAdminStatus.0.ipv6.unicast.ipv6."20:01:07:f8:00:91:00:00:00:00:00:00:00:00:02:38" = start
hwBgpPeerAdminStatus.0.ipv6.unicast.ipv6."2a:01:03:90:06:66:04:25:00:00:00:00:00:00:00:01" = start
hwBgpPeerAdminStatus.0.ipv6.unicast.ipv6."2a:03:27:60:00:01:00:01:00:00:00:00:00:00:00:02" = start
My install is always on newest master version of librenms.
@PipoCanaja So i looked into sql database and there I can see that I don’t have a data in bgpPeers_cbgp table at all for my Huawei NE router with device_id 470
Here is an output of
SELECT * FROM bgpPeers WHERE device_id = 470;
| bgpPeer_id | device_id | vrf_id | astext | bgpPeerIdentifier | bgpPeerRemoteAs | bgpPeerState | bgpPeerAdminStatus | bgpLocalAddr | bgpPeerRemoteAddr | bgpPeerDescr | bgpPeerInUpdates | bgpPeerOutUpdates | bgpPeerInTotalMessages | bgpPeerOutTotalMessages | bgpPeerFsmEstablishedTime | bgpPeerInUpdateElapsedTime | context_name |
| 457 | 470 | NULL | VNET-AS, SK | 86.110.242.90 | 29405 | established | start | 86.110.242.91 | 86.110.242.90 | | 3622579 | 2866 | 3684211 | 76538 | 1882921 | 17 | NULL |
| 458 | 470 | NULL | EMAX_AS1 http://www.e-max.sk, SK | 188.120.0.0 | 49115 | established | start | 188.120.0.1 | 188.120.0.0 | | 763 | 13 | 38112 | 43171 | 2241175 | 278 | NULL |
| 461 | 470 | NULL | NIXSK-RS NIX.CZ z.s.p.o., SK | 194.30.187.1 | 47627 | established | start | 194.30.187.167 | 194.30.187.1 | | 7473581 | 4147 | 7511065 | 41984 | 1962280 | 7 | NULL |
| 462 | 470 | NULL | NIXSK-RS NIX.CZ z.s.p.o., SK | 194.30.187.2 | 47627 | established | start | 194.30.187.167 | 194.30.187.2 | | 1447867 | 186 | 1457482 | 9900 | 503443 | 7 | NULL |
| 463 | 470 | NULL | ROOTSERV, US | 194.30.187.238 | 112 | established | start | 194.30.187.167 | 194.30.187.238 | | 3 | 1642 | 37404 | 39471 | 1962280 | 1211116 | NULL |
| 524 | 470 | NULL | NIXSK-RS NIX.CZ z.s.p.o., SK | 2001:7f8:91::11 | 47627 | established | | | 2001:7F8:91::11 | | 1891251 | 192 | 1928689 | 38028 | 1962281 | 0 | NULL |
| 525 | 470 | NULL | NIXSK-RS NIX.CZ z.s.p.o., SK | 2001:7f8:91::12 | 47627 | established | | | 2001:7F8:91::12 | | 454149 | 38 | 463750 | 9754 | 503466 | 0 | NULL |
| 526 | 470 | NULL | ROOTSERV, US | 2001:7f8:91::238 | 112 | established | | | 2001:7F8:91::238 | | 3 | 68 | 37383 | 37895 | 1962274 | 0 | NULL |
| 567 | 470 | NULL | EMAX_AS1 http://www.e-max.sk, SK | 188.120.0.145 | 49115 | established | start | 188.120.0.144 | 188.120.0.145 | | 6 | 2 | 29994 | 34708 | 1799459 | 645603 | NULL |
| 603 | 470 | NULL | EMAX_AS1 http://www.e-max.sk, SK | 2a03:2760:1:1::2 | 49115 | established | | | 2A03:2760:1:1::2 | | 3 | 71 | 27360 | 31736 | 1641593 | 0 | NULL |
| 825 | 470 | NULL | VNET-AS, SK | 2a01:390:666:425::1 | 29405 | established | stop | 0.0.0.0 | 2A01:390:666:425::1 | | 181895 | 2 | 184498 | 3496 | 89087 | 0 | NULL |
11 rows in set (0.00 sec)
where you can see that some data are missing for ipv6 peers.
and when I run
SELECT * FROM bgpPeers_cbgp WHERE device_id = 470;
I got
Empty set (0.00 sec)
So that is a reason why I can’t see Family and also prefixes with value 0 for clear graphs.
Provide me snmpwalk so I can simulate your device, and I’ll fix it. I don’t have any device providing prefixes numbers here so I have to work on simulated devices only.
I can see that problem also on Huawei S5720I-12X-SI-ACthere is also no data in bgpPeers_cbgp table. But i think that in past I can see prefixes numbers. snmpwalk fo ne40 is really so big and it taking so long because we have 2x Full BGP and it will consume more cpu to take it.
@jozefrebjak
Again, without the device, I cannot do much . I need the snmpwalk to replicate it. Do you have some spare/test device on which you could produce the behaviour, collect the snmp data and send it ?
@PipoCanaja Do you have some S Series switches with BGP ? Because that problem is there for all VRP devices not only NE40xx devices. There is no data added to bgpPeers_cbgp table. So that is a reason why we cant’s see prefixes etc. for VRP devices.
Here is the snmpwalk of Huawei NE40E-M2K-B which is using HUAWEI-BGP-VPN-MIB
But there is also problem with S-Series switches which are using generic BGP MIB
OK. I’ll see if I can find out on an S5700 switch. Will update you. Which firmware version are you running ?
@PipoCanaja Here is the list of my Huawei swittches
