An interface called VL50_CAMERAS is ignored because includes matching text (‘ras’). All other interfaces are detected correctly.
Similar problem reported here recently too.
Code section from debugging.
SQL[SELECT * FROM `ports` WHERE `device_id` = ? ORDER BY port_id [179] 0.69ms]
Using ifDescr as ifAlias
SQL[UPDATE `ports` set `ifDescr`=?,`ifName`=?,`ifAlias`=?,`ifType`=?,`ifOperStatus`=?,`ifIndex`=? WHERE `port_id` = ? ["lo0","lo0","lo0","softwareLoopback","up",1,106191] 0.29ms]
SQL[UPDATE `ports` set `ifDescr`=?,`ifName`=?,`ifAlias`=?,`ifType`=?,`ifOperStatus`=?,`ifIndex`=? WHERE `port_id` = ? ["vmxnet3s0","vmxnet3s0","vmxnet3s0","ethernetCsmacd","up",2,106192] 0.22ms]
SQL[UPDATE `ports` set `ifDescr`=?,`ifName`=?,`ifAlias`=?,`ifType`=?,`ifOperStatus`=?,`ifIndex`=? WHERE `port_id` = ? ["vmxnet3s2","vmxnet3s2","vmxnet3s2","ethernetCsmacd","up",3,106193] 0.21ms]
SQL[UPDATE `ports` set `ifDescr`=?,`ifName`=?,`ifAlias`=?,`ifType`=?,`ifOperStatus`=?,`ifIndex`=? WHERE `port_id` = ? ["VL20_VPN0","VL20_VPN0","VL20_VPN0","ethernetCsmacd","up",4,106194] 0.41ms]
**ignored by ifDescr: VL50_CAMERAS0 (matched: ras) **
**X**
** Using ifDescr as ifAlias**
SQL[UPDATE `ports` set `ifDescr`=?,`ifName`=?,`ifAlias`=?,`ifType`=?,`ifOperStatus`=?,`ifIndex`=? WHERE `port_id` = ? ["VL90_GENERAL0","VL90_GENERAL0","VL90_GENERAL0","ethernetCsmacd","up",6,106195] 0.27ms]
SQL[UPDATE `ports` set `ifDescr`=?,`ifName`=?,`ifAlias`=?,`ifType`=?,`ifOperStatus`=?,`ifIndex`=? WHERE `port_id` = ? ["VL70_VIDEO0","VL70_VIDEO0","VL70_VIDEO0","ethernetCsmacd","up",7,106196] 0.29ms]
