InvalidRrdTypeException on sensors module
Dear Community!
Some of my devices in LibreNMS have sensors module. However since some updates ago, this is completely broken for me, I can’t see any graphs about sensors.
Validate config:
LibreNMS  | 22.7.0
DB Schema | 2022_07_19_081224_plugins_unique_index (243)
PHP       | 8.1.17
Python    | 3.10.10
MySQL     | 10.4.29-MariaDB-1:10.4.29+maria~ubu2004
SNMP      | 5.9.3
[OK]    Installed from the official Docker image; no Composer required
[OK]
[OK]    MySQl and PHP time match
[INFO]  fping FAILURES can be ignored if running LibreNMS in a jail without ::1. You may want to test it manually: fping ::1
[FAIL]  /usr/sbin/fping6 could not be executed. /usr/sbin/fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exclusions may be required.
 (/usr/sbin/fping: can't create socket (must run as root?))
[FAIL]  /usr/sbin/fping6 should have CAP_NET_RAW!
        setcap cap_net_raw+ep /usr/sbin/fping6
[OK]    rrd_dir is writable
[WARN]  Updates are managed through the official Docker image
The error I get in Event Log:
Error polling sensors module. Check log file for more details.
Error is librenms.log:
[2023-06-06T11:24:01.773560+02:00] production.ERROR: Error polling sensors module for 10.0.13.1. LibreNMS\Exceptions\InvalidRrdTypeException:  is not valid, must be: GAUGE | DERIVE | COUNTER | ABSOLUTE | DCOUNTER | DDERIVE in /opt/librenms/LibreNMS/RRD/RrdDefinition.php:122
Stack trace:
#0 /opt/librenms/LibreNMS/RRD/RrdDefinition.php(65): LibreNMS\RRD\RrdDefinition->checkType()
#1 /opt/librenms/includes/polling/functions.inc.php(189): LibreNMS\RRD\RrdDefinition->addDataset()
#2 /opt/librenms/includes/polling/functions.inc.php(135): record_sensor_data()
#3 /opt/librenms/includes/polling/sensors.inc.php(28): poll_sensor()
#4 /opt/librenms/includes/polling/functions.inc.php(340): include('...')
#5 /opt/librenms/poller.php(126): poll_device()
#6 {main}
[2023-06-06T11:24:01.782259+02:00] production.ERROR:  is not valid, must be: GAUGE | DERIVE | COUNTER | ABSOLUTE | DCOUNTER | DDERIVE {"exception":"[object] (LibreNMS\\Exceptions\\InvalidRrdTypeException(code: 0):  is not valid, must be: GAUGE | DERIVE | COUNTER | ABSOLUTE | DCOUNTER | DDERIVE at /opt/librenms/LibreNMS/RRD/RrdDefinition.php:122)"}
Any idea for this error?
Anyone has ideas how to fix this?
@murrant any idea?
I still have this issue and I was unable to resolve it.
It seems that the files are not created for sensors, but ownership looks ok for folders
