LibreNMS Graph is not continuous
I found the issue the graph is not continuous , pleas kindly advise
./validate.php
LibreNMS 22.9.0-3-g06c361c2b
DB Schema 2022_09_03_091314_update_ports_adsl_table_with_defaults (246)
PHP 7.4.3
Python 3.8.10
Database MariaDB 10.3.34-MariaDB-0ubuntu0.20.04.1
SNMP 5.8
[OK] Composer Version: 2.4.4
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[WARN] Your install is over 24 hours out of date, last update: Thu, 29 Sep 2022 04:32:10 +0000
You can switch back to master with git checkout master
You have mail in /var/mail/librenms
Below is devices and ports that I’ve in system.
Multiple things could be causing this. The overall cause is Libre isn’t finishing polling thr device/s during a polling cycle.
-Start by verifying there’s no resource contention within Libre. (CPU/Memory etc look good)
-Run poller debug on the problem devices and see how long a polling cycle takes. If it’s just barely finishing polling in a polling cycle, look into disabling Libre polling modules for that device.
-If there aren’t modules you’re willing to disable then look into extending your polling cycles. (This should be last resort since a system-wide setting and would affect all devices)
I recently ran into a similar issue for a few devices in my network. The ports module is the biggest hog of time, but also quite important. I ended up deciding that I didn’t need ports for those devices.
To reiterate what @electrocret said, there is a list of sanity checking here: Performance - LibreNMS Docs
I also had particular success tuning SNMP Max Repeaters when I was monitoring things over variable latency, which I over-explain here: Debugging graph spikes from high latency links - #6 by rhinoau
My issues were causing discovery interruptions and scambling my data and spiking traffic, I was still completing polling within the window, though the max repeaters tuning dramatically reduced my polling time.
Poller performance graphs are a good place to start to see what is taking up the time and maybe blowing out polling past the 5 minute (default) window:
The log tab on that same page shows each device total time as it comes in too so you can start to target the slower devices.
