I have an issue these last few weeks where map markers have suddenly disappeared from the Worldmap dashboard widget - it just displays an empty map. Have tried changing the up / down / both filter settings for the widget with no difference. The markers do still display correctly in the full screen worldmap however. Has something changed between the two?
Suggestions on where / what to check appreciated!
- The output of
./validate.php
Component | Version |
LibreNMS | 1.47-22-gdef8b3e51 |
DB Schema | 279 |
PHP | 7.2.10-0ubuntu0.18.04.1 |
MySQL | 5.7.24-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.0
