Mdadm Application
Trying to set up the mdadm application - and having a bit of a challenge with the configuration file (mdadm.conf). There is no info in the online documentation, nor on Github … so just not sure of the format the file needs to be in (i.e. info to capture).
Any pointers?
Thanks!
OK, figured out the issue here - the current script is not working properly in Ubuntu … will get it corrected, submit PR. Thanks!
I got it working properly but database states seem incorrect if there are multiple mdadm arrays. Did you get this fixed?
