Multiple locations with conflicting IP network
I am currently in the process on implementing as new instance of librenms and I am facing an issue with multiple remote client sites/locations having the same IP networks
Historically I have utilised site to site vpns but where over time we had reconfigured client networks with different IP subnets so they were unique IP networks between all clients and clients sites.
Unfortunately that isn’t the case where I am at currently, therefore is there any way to:
-Monitor and add devices with conflicting IP network whether it be with a SNMP proxy service or via a site to site vpn
-Ant third party agent based integration that can be used as an single SNMP collector that can relay onto the Librenms instance a bit like Auvik, Atera etc
Many thanks in advance for any response
Ross
if you are using distributed polling, below thread has solution
