I had the issues described in below thread:
I have two devices somehow added as below
[libre-device]
I tried to edit/overwrite/maintenance mode. But there is no way i can delete them. After deleting confirmation it says ‘no such host’ . But the devices remains in the system. How to delete these ?
So i deleted the ~200 devices in this state with command:
DELETE FROM devices
WHERE device_id
=xxx;
Now when i reboot the server it hangs in shutting down MySQL.
Tried waiting 10 minutes but no luck.
The installation was done following Installing LibreNMS - LibreNMS Docs
Any suggestions to fix this would be apricated.
/Peter
There are other ways to kill a unresponsive application.
Search for the app
ps -aux | grep application_name
Find the PID number and kill the app with
sudo -9 kill PID
Google is your friend.
Yes that of course works.
But its not a solution to the actual issue.
Every time i reboot the server it hangs for ever until i manually kill it
/Peter
Did you also try to stop your poller first?
How would i do that ? the only service i see related to librenms is php7.4-fpm.
Stopping that and then mysql changes nothing:
service php7.4-fpm stop
service mysql stop
It just hangs on mysql stop.
/Peter
Are you running the dispatcher service or the cron based poller?
I had the same problems once. I always have to stop my cron based poller
in the /etc/cron.d/librenms file that i can safely shutdown the server. (i just comment the lines out in that file) I dunno if this would help in your case/scenery
Yes i see the cron jobs.
Doubt it will help me.
There seem to be some kind of deadlock in the database after i had the issue:
[libre-device]
Guess i will just reinstall and not mess around with auto discovery that got me in this situation.
/Peter
system
Closed
15 July 2021 16:33
8
