I have two devices somehow added as below
I tried to edit/overwrite/maintenance mode. But there is no way i can delete them. After deleting confirmation it says ‘no such host’ . But the devices remains in the system. How to delete these ?
same issue here, @jasim_alam did you get the issue resolved ?
Only way to delete these is via SQL DELETE FROM `devices` WHERE `device_id`=999999999;
(where 999999999 is the device_id in the url)
I still haven’t figure out what is adding these…
can you walk me step by step ?
You have to enter mysql cli:
mysql -u librenms -p librenms
That will ask you for a password, you can look it at .env
or config.php
Then run the query murrant said with the correct device_id.
THANKS ! worked
@murrant I think this happened to me in the past and was part of a failed test.
to find device_id in database, just do like this :
MariaDB [librenms]> SELECT device_id, hostname, sysName, ip FROM devices;
Thanks. it works.
