i have problem with seeing version of config, i see only last configuration in librenms
I have browsed through this community, found several same issues, but in all there was error in ouput not being git - as per config, i got only output git
→ ./validate.php
LibreNMS | 1.61-61-gfb7c578fd
DB Schema | 2020_02_10_223323_create_alert_location_map_table (159)
PHP | 7.2.28-4+0~20200224.38+debian9~1.gbp1ca010
MySQL | 10.1.44-MariaDB-0+deb9u1
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.3
Blockquote
[OK] Composer Version: 1.10.1
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Files:
/opt/librenms/.git/index
i dont think issue is related to errors from validate, we got automated git which backups all servers, but please tell me if i am wrong ![]()
my oxidized config:
librenms config regards oxidized:
$config[‘oxidized’][‘enabled’] = TRUE;
$config[‘oxidized’][‘url’] = ‘http://127.0.0.1:8888’;
$config[‘oxidized’][‘features’][‘versioning’] = true;
$config[‘oxidized’][‘reload_nodes’] = true;
Thanks for any help!
