Guys,
Can anyone explain me how to fix the errors below?
[root@dl1-librenms-srv01 Weathermap]# ./weathermap.php --config configs/dl1-map.conf --output output/dl1-map.png --htmloutput output/dl1-map.html
PHP Deprecated: Non-static method PEAR::isError() should not be called statically in /usr/share/pear/Console/Getopt.php on line 109
PHP Deprecated: Non-static method PEAR::isError() should not be called statically in /usr/share/pear/Console/Getopt.php on line 154
PHP Deprecated: Non-static method PEAR::isError() should not be called statically in /opt/librenms/html/plugins/Weathermap/weathermap.php on line 64
WARNING: configs/dl1-map.conf: OVERLIBGRAPH is used, but HTMLSTYLE is static. This is probably wrong. [WMWARN41]
WARNING: configs/dl1-map.conf: Target ./dl1ert01.pan.local/port-id474.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 7-8, target: ./dl1ert01.pan.local/port-id474.rrd:INOCTETS:OUTOCTETS on config line 149 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ert01.pan.local/port-id463.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 7-node05739, target: ./dl1ert01.pan.local/port-id463.rrd:INOCTETS:OUTOCTETS on config line 157 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ert02.pan.local/port-id409.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 8-node05799, target: ./dl1ert02.pan.local/port-id409.rrd:INOCTETS:OUTOCTETS on config line 165 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ert01.pan.local/port-id465.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 7-node05840, target: ./dl1ert01.pan.local/port-id465.rrd:INOCTETS:OUTOCTETS on config line 173 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ert02.pan.local/port-id411.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 8-node05858, target: ./dl1ert02.pan.local/port-id411.rrd:INOCTETS:OUTOCTETS on config line 181 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ets01.pan.local/port-id789.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 14-7, target: ./dl1ets01.pan.local/port-id789.rrd:INOCTETS:OUTOCTETS on config line 189 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ets01.pan.local/port-id837.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 14-15, target: ./dl1ets01.pan.local/port-id837.rrd:INOCTETS:OUTOCTETS on config line 197 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1ets02.pan.local/port-id737.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 15-8, target: ./dl1ets02.pan.local/port-id737.rrd:INOCTETS:OUTOCTETS on config line 205 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its01.pan.local/port-id155.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 1-2, target: ./dl1its01.pan.local/port-id155.rrd:INOCTETS:OUTOCTETS on config line 213 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its01.pan.local/port-id84.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 1-node00591, target: ./dl1its01.pan.local/port-id84.rrd:INOCTETS:OUTOCTETS on config line 221 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its02.pan.local/port-id1.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 2-node00611, target: ./dl1its02.pan.local/port-id1.rrd:INOCTETS:OUTOCTETS on config line 229 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its01.pan.local/port-id89.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 1-3, target: ./dl1its01.pan.local/port-id89.rrd:INOCTETS:OUTOCTETS on config line 237 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its02.pan.local/port-id6.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 2-3, target: ./dl1its02.pan.local/port-id6.rrd:INOCTETS:OUTOCTETS on config line 246 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its01.pan.local/port-id88.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 1-6, target: ./dl1its01.pan.local/port-id88.rrd:INOCTETS:OUTOCTETS on config line 254 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
WARNING: configs/dl1-map.conf: Target ./dl1its02.pan.local/port-id5.rrd doesn’t exist. Is it a file? [WMRRD06]
WARNING: configs/dl1-map.conf: ReadData: LINK 2-6, target: ./dl1its02.pan.local/port-id5.rrd:INOCTETS:OUTOCTETS on config line 262 of configs/dl1-map.conf had no valid data, according to WeatherMapDataSource_rrd
PHP Notice: Undefined property: WeatherMap::$basehref in /opt/librenms/html/plugins/Weathermap/weathermap.php on line 287
