Hi!
After upgrading my Ubiquiti switches to firmware 4.0.14.9736 I lost some sensors in LibreNMS. Previous firmware was 3.9.54.9373 and was able to display multiple temperature sensors and CPU usage. Please note the output from LibreNMS webgui log below.
Release notes from 4.0.14.3976: https://community.ubnt.com/t5/UniFi-Updates-Blog/FIRMWARE-4-0-14-9736-for-UAP-USW-has-been-released-Stable/ba-p/2610088
Any thoughts? Thanks!
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: state boxServicesTempUnitEntry boxServicesTempUnitState.1 Chassis state | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: state boxServicesTempSensorsEntry boxServicesTempSensorState.1.0 Temp Sensor 1.0 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: state boxServicesTempSensorsEntry boxServicesTempSensorState.1.1 Temp Sensor 1.1 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: state boxServicesTempSensorsEntry boxServicesTempSensorState.1.2 Temp Sensor 1.2 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: state boxServicesTempSensorsEntry boxServicesTempSensorState.1.3 Temp Sensor 1.3 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: temperature edgeswitch boxServicesTempSensorTemperature.1.0 Temperature 1.0 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: temperature edgeswitch boxServicesTempSensorTemperature.1.1 Temperature 1.1 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: temperature edgeswitch boxServicesTempSensorTemperature.1.2 Temperature 1.2 | System |
| 2019-01-02 00:55:05 | sensor | sw-tvattstuga | Sensor Deleted: temperature edgeswitch boxServicesTempSensorTemperature.1.3 Temperature 1.3 | System |
| 2019-01-02 00:55:04 | processors | sw-tvattstuga | Processor Removed: edgeswitch 0 Processor | System |
| 2019-01-02 00:52:02 | alert | sw-tvattstuga | Issued critical alert for rule ‘Sensor under limit’ to transport ‘telegram’ | System |
| 2019-01-02 00:50:23 | system | sw-tvattstuga | OS Version -> 4.0.10.9653 | System |
Output from validate.php:
./validate.php`
validate.php
| LibreNMS | 1.47-12-g506f48d |
| DB Schema | 278 |
| PHP | 7.1.25-1+ubuntu14.04.1+deb.sury.org+1 |
| MySQL | 5.5.62-0ubuntu0.14.04.1 |
| RRDTool | 1.4.7 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.0
[WARN] Your RRD directory is owned by root, please consider changing over to user a non-root user
Modified Files:
logs/.gitignore
Output from discovery.php and poller.php:
./discovery.php
https://p.libren.ms/view/4b01fafb
./poller.php
https://p.libren.ms/view/3a648136
Regards,
Fredrik.
