i have uncommented $config[‘update_channel’] = ‘release’;
i get no errors from ./daily
but when i do ./validate i first got alot of errors,i have excuted the sql commands that were possible but i got a few that is not working:
ALTER TABLE sensors CHANGE sensor_idsensor_id int(11) NOT NULL auto_increment; ERROR: Cannot change column ‘sensor_id’: used in a foreign key constraint ‘sensors_to_state_indexes_sensor_id_foreign’ of table ‘librenms.sensors_to_state_indexes’
ALTER TABLE sensors_to_state_indexes CHANGE sensor_idsensor_id int(11) NOT NULL ; ERROR: Cannot change column ‘sensor_id’: used in a foreign key constraint ‘sensors_to_state_indexes_sensor_id_foreign’
ALTER TABLE sensors_to_state_indexes CHANGE state_index_idstate_index_id int(11) NOT NULL ; ERROR: Cannot change column ‘state_index_id’: used in a foreign key constraint ‘sensors_to_state_indexes_ibfk_1’
ALTER TABLE state_indexes CHANGE state_index_idstate_index_id int(11) NOT NULL auto_increment; ERROR: Cannot change column ‘state_index_id’: used in a foreign key constraint ‘sensors_to_state_indexes_ibfk_1’ of table ‘librenms.sensors_to_state_indexes’
How do i solve this?
may be worth knowing im running the commands trough phpmyadmin if that matters
I’m on 1.48.1 (Wed Jan 30 2019 20:53:43 GMT+0000) and seeing this when running a validation - is it fine to go ahead and run the suggested SQL commands?
Ah thanks - I didn’t quite see the difference as I was searching for sensors_to_state_indexes rather than the full error. Unfortunately when I try to import the 278 SQL schema in the linked post, I get the following error;
ERROR 3061 (42000) at line 113: User variable name 'FOREIGN_KEY_sensors_to_state_indexes_ibfk_1_ON_TABLE_sensors_to_state_indexes_EXISTS' is illegal
As a result, I cannot apply the remaining two SQL statements that the validate script suggests;
MySQL [librenms]> ALTER TABLE `sensors_to_state_indexes` CHANGE `state_index_id` `state_index_id` int(10) unsigned NOT NULL ;
ERROR 1832 (HY000): Cannot change column 'state_index_id': used in a foreign key constraint 'sensors_to_state_indexes_ibfk_1'
MySQL [librenms]> ALTER TABLE `state_indexes` CHANGE `state_index_id` `state_index_id` int(10) unsigned NOT NULL auto_increment;
ERROR 1833 (HY000): Cannot change column 'state_index_id': used in a foreign key constraint 'sensors_to_state_indexes_ibfk_1' of table 'librenms.sensors_to_state_indexes'
I can split this off to a seperate thread now that I know it is a different issue if that’s best?
Thank you - you’re right. My version of 278.sql comes from the 1.48.1 tag, however there’s one commit to that file since then in master which fixes SQL variable naming issues (PR #9766).
I manually updated sql-schema/278.sql to the master version, applied it to my database and then the validation only flagged one missing database entry (ALTER TABLEeventlogCHANGEdevice_iddevice_idint(10) unsigned NULL ;). After applying this, the validation completes without error (aside from noting that sql-schema/278.sql has been modified locally, but i’ll switch it back to the 1.48.1 tag version now that i’ve been able to resolve this).
