i need to create an alert rule for our firewall systems.
we’re using a internal ipls network by our provider. with librenms i get the traffic informations by a port of the router. this port is configured to 1gbit speed but our WAN speed is 8 mbit/s.
so now i want to create an alert rule when the traffic over time X is by 7mbit/s.
how can i configure that?
If your interface speed is 1000, then: macros.port_usage_perc >= 0.7 AND macros.port_up = 1 AND macros.port = 1
and if your port has a description it could look like:
macros.port_usage_perc >= 0.7 AND macros.port_up = 1 AND macros.port = 1 AND ports.ifAlias LIKE 'thisismyportdesciption%'
Then you might want to MAP it to a firewall or firewall group in the alert.
You should be able to control time, by changing the delay e.g if you have 5 minute polling time, then 6m you would be sure would cover 2 polls (10 mins), so it would only alert if >=7Mbps over 10 mins e.g
Ahh yes looks like validation stops you from doing this,
In that case you need a workaround, you could try changing your interface Speed on Librenms to 100, and put the port usage to 7 . Or if you know the SQL query you can alert with that.
To change interface speed to go device -> edit -> port settings -> change the port from 1Gbps “1000000000” to 100Mbps “100000000”
EDIT: I just realized you said “over time” not sure if this will do what you want, I’m just trying to help.
EDIT2: Just to clarify this is the key piece here:
You will need to go back to “Main” tab after and fill in the Title, and put something random into the builder alert, which won’t be effective, but again more of a validation issue.
