laf
1
Features
- Added powerdns dnsdist application (#7987)
- Added ZFS support for FreeBSD (#7938)
- Added snmp_getnext_multio() function (#8052)
- Clear OS defs cache on poller/discovery debug (#8061)
- Script to rename mibs to proper names (#8068)
Bugfixes
daily.sh Updated to resolve release version issues (#8172)
- Make consistent with other authorisers (#8151)
- Pushover message fix to enable templates (#8118)
- Bgp-peers junos empty afi-safi names (#8083)
- Fixed the default fping config + changed variable name (#8060)
- Override -H for check_load service. Fixed backslash escaping. (#8020)
- Fix can’t find CPQHOST-MIB (#8024)
- Bgp-peers add missing os junos safi values (#8018)
- Cisco-vrf discovery for device os junos (#8009)
- Stop stripping html tages from snmp creds (#7951)
- Fixed bugs in bgp-peers poller (#7976)
- Fix mark all unread notifications (#7999)
- Fix deletion of services + select query (#8030)
- Moved sysDescr snmp call to snmp_get_multi_oid() in core poller (#8062)
- Fixed bad queries for top device widget (#8105)
- Stop including disabled ports in traffic overview (#8107)
- Specify table name for list_devices API call (#8132)
- Fixed Palo Alto HA alert rule (#8138)
- Fixed arp table duplicates (#8147)
- Fixed normal user access to performance tab (#8150)
- Changed is_file() to rrdtool_check_rrd_exists() (#8152)
Documentation
- Emphasize snmpsim is required for most tests (#8059)
- Doc api fixes (#7950)
- Added ports purge to cleanup options (#7970)
Refactoring
- Moved routeros sensors to yaml + fixed divisors (#7946)
- Remove all old style snmp calls (#7924)
- Fail2ban update and removal of FW checking (#7936)
- Refactor freeradius appplication metrics (#8002)
- Move ignore_storage call to discover_storage (#7973)
- Updated poller/discovery to use numeric sysObjectID (#7922)
- Move installs to php53 branch for php version < 5.6.4 (#8042)
- Rename cisco-vrf to vrf and enabled junos (#8033)
- Updated BGP Peers (#7972)
Devices
- Added Support for cambium PTP 300, 500, 600 and 800 (#7998)
- Added support for ArbOS (#8055)
- Added processor and mempools for EdgeCore switch (#7850)
- Updated Cisco ACS Detection (#8013)
- Added Rittal IT Chiller / Carel pCOweb card (#7826)
- Added cyberpower RMCARD 202 Support (#7964)
- Added additional detection for CyberPower devices (#7931)
- Added further detection for Sophos UTM devices (#7953)
- Added Cambium cnPilot Support (#7898)
- Added more sensor support for RouterOS (Mikrotik) + Test data (#7930)
- Added Checkpoint Gaia Sensor (#8088)
- Added Dell iDRAC Global System Sensor (#8012)
- Added CheckPoint SecurePlatform support (#8000)
- Fixed AirOS version and Hardware (#8034)
- Fixed UniFi AP hardware and firmware revision (#8005)
- Added Hillstone StoneOS detection (#7982)
- Added Allied Telesis CPU support (#8111)
- Updated legacy Allied Telesis hardware support (#8071)
- Added EER and Water Florw Rate for Rittal Chillers (#8104)
- Added memory and temp polling for Dlink (#8076)
- Added Hardware/Version/Serial support for Synology (#8087)
- Updated hardware for certain awplus devices (#8123)
- Updated FortiManager support (#8102)
- Added suspended state for panos (#8125)
WebUI
- Added back devices sort by status (#8103)
- Small graylog cleanup (#8057)
- Small eventlog cleanup (#8056)
- Added OpenWRT icon (#8054)
- Devices header cleanup (#8039)
- Added validation for Oxidized API URL config (#7978)
- Wireless pages refresh (#7836)
- HPMSM added CPU,Memory to Overview (#7949)
- Added Single server details widget (#7923)
- Improved Services page (#7628)
- Improved Alerts page (#7765)
- Improved Eventlog page (#7793)
- Improved Syslog page (#7796)
- Improved Devices page (#7809)
- Improved Ports page (#7827)
- Improved Graylog page (#7832)
- Improved Health / Sensors page (#7834)
- Improved Wireless page (#7836)
- Improved Applications page (#7994)
- Added Oxidized config validator (#7983)
- Added settings validations (#8037)
API
- Added add_service_for_host endpoint to API (#8113)
- Added dependency info for devices/device api calls (#8058)
- Added 404 fallback for bad / invalid calls (#7952)
- Added routing and resources API calls (#8017)
Alerting
- Updated Pushover to use templates (#8118)
