##1.48
(2019-01-28)
A big thank you to the following 31 contributors this last month:
- murrant (59)
- PipoCanaja (7)
- vitalisator (3)
- laf (3)
- gpant (2)
- Swashy (2)
- JoshWeepie (2)
- kkrumm1 (2)
- djamp42 (2)
- dharpster (1)
- cppmonkey (1)
- emestee (1)
- marvink87 (1)
- GitStoph (1)
- sjtarik (1)
- TheGreatDoc (1)
- acl (1)
- martijn-schmidt (1)
- evheros (1)
- kiwibrew (1)
- nova-2nd (1)
- pheinrichs (1)
- amtypaldos (1)
- Kal42 (1)
- angryp (1)
- mikecentola (1)
- jozefrebjak (1)
- tim427 (1)
- twelch24 (1)
- sanegaming (1)
- zoc (1)
Bug
- Fix Exception in GraylogAPI.php (#9617) - zoc
- Fix devices page search & OS loading (#9752) - murrant
- Revert “Mattermost Alert Transport” (#9743) - TheGreatDoc
- Validate default config seeder (#9723) - murrant
- Fix missing config setting in DB seed alert.transports.mail (#9721) - murrant
- Fix sql schema 278 (#9715) - murrant
- Alert Rules: fix for critical and warning rule (#9688) - kkrumm1
- Fix if discover overwritting fields (#9643) - evheros
- Fix validate error (#9700) - murrant
- Update Mimosa.php (#9695) - kiwibrew
- Rename librenms script to lnms (#9696) - murrant
- Seeds can run on existing (#9689) - murrant
- Run both legacy schema and migrations in the same run if needed (#9686) - murrant
- Fix dbSchema 1000 skipping schema files (#9685) - murrant
- Removed NO_AUTO_CREATE_USER from mysql strict to support MySQL 8 (#9668) - laf
- Increase snmp execution time limit to 20 minutes (#9639) - murrant
- Add group to sensor 1st discovery + template syntax {{ $xxx }} (#9667) - PipoCanaja
- Order by support for availability map widget (#9663) - murrant
- Remove broken routeros signal sensor (#9650) - murrant
- Fix sentry3 voltage sensors (#9649) - murrant
- Fix wireless sensor edit messages and collection alert rule (#9624) - murrant
- Fix poller.php with missing -h (#9621) - murrant
- Fix Infoblox NIOS graphs (#9620) - murrant
- Fix .gitingore “changed” files with github-remove script (#9616) - murrant
- Fix orphaned dashboards (#9590) - murrant
Feature
- Pressing enter on global search goes to the first result (#9587) - murrant
- Added Mattermost Transport (#9749) - gpant
- Lnms bash completion (#9747) - murrant
- Hook many commands into the lnms script (#9699) - murrant
- Add lnms command (#9619) - murrant
- Allow grouping of sensors (#9606) - murrant
- Validate database constraints (#9670) - murrant
Webui
- Rewrite devices page backend (and a little frontend) (#9726) - murrant
- Handle db update errors better in the installer (#9701) - murrant
- Improve display for 802.1X NAC (#9706) - PipoCanaja
- Refactor FDB Tables to Laravel (#9669) - murrant
- Better IP exists feedback when adding a device (#9697) - murrant
- Sort device select by hostname (#9607) - murrant
- Alert schedule refactor (#9514) - murrant
- Removed Legacy Transport UI https://t.libren.ms/deprecation-alerting (#9552) - laf
Alerting
- Mattermost Alert Transport (#9711) - gpant
- Added Alerta Alert Transport (#9673) - GitStoph
- Fix first column validate (#9683) - murrant
- Added Alertmanager transport (#9637) - angryp
Device
- Adding temp/humidity sensors for raritan px2 (#9719) - sjtarik
- FreeBSD mempools Fix (#9659) - vitalisator
- Adding Sonicwall SMA 400 support (#9555) - marvink87
- Support for Alcatel OmniPCX (#9375) - PipoCanaja
- Improve index check for compatibility with different versions of the DDOS (#9698) - acl
- Eltek Valere more sensors (#9713) - murrant
- New OS: Schleifenbauer, entity-physical improvements, various html page fixes (#9471) - martijn-schmidt
- Huawei iBMC absent state grey (#9691) - murrant
- Nokia vrf bgp (#9622) - vitalisator
- Implement NAC data polling (#9592) - PipoCanaja
- Cable Modem Graphs for TopVision OS (#9679) - djamp42
- Merge ethernetprobe2 into akcp and improve akcp (#9465) - murrant
- Sorting States using groups (#9666) - PipoCanaja
- Added ignore mount point effects macOS (#9652) - kkrumm1
- EATON-MGEUPS: Added sensors for temperature and humidity from … (#9647) - Kal42
- Fix some issues with sensor limits (#9638) - murrant
- Added support for Vigintos Modulator & Ampiflier (#9488) - jozefrebjak
- Device Support for Pegasus (#9641) - vitalisator
- TopVision CMTS (#9627) - djamp42
- ZyXEL Telemetry - XGS4600-32F (#9599) - cppmonkey
Security
- Rewrite netcmd and ripe whois tools (#9724) - murrant
- Update dependencies (#9657) - murrant
Documentation
- Update docs on mkdocs (#9631) - emestee
- New OS: Suggest -d in discovery.php to clear cache (#9602) - murrant
- FAQ LibreNMS and MIBs (#9664) - murrant
- Update Fast-Ping-Check.md (#9705) - sanegaming
- Update poller_modules documentation for NAC (#9704) - PipoCanaja
- Docs:Update SNMP-Trap-Handler.md (#9654) - JoshWeepie
- Oxidized JunOS syslog hook documentation fix (#9676) - nova-2nd
- Reference config options for new beta poller service (#9644) - Swashy
