1.56
(2019-09-30)
A big thank you to the following 35 contributors this last month:
- pobradovic08 (5)
- vitalisator (5)
- SourceDoctor (4)
- jasoncheng7115 (4)
- murrant (3)
- Bounzz (2)
- bestlong (2)
- Jellyfrog (2)
- wilreichert (1)
- VVelox (1)
- dsgagi (1)
- nwautomator (1)
- nistorj (1)
- rsys-dev (1)
- hanserasmus (1)
- lfkeitel (1)
- erotel (1)
- garysteers (1)
- takenalias (1)
- feuerrot (1)
- deajan (1)
- Rosiak (1)
- SniperVegeta (1)
- jozefrebjak (1)
- PipoCanaja (1)
- Derova (1)
- seros1521 (1)
- brownowski (1)
- fbourqui (1)
- dGs- (1)
- YisroelTech (1)
- CameronMunroe (1)
- soto2080 (1)
- Cormoran96 (1)
- FTBZ (1)
Device
- Added Cisco QFP processor (#10622) - pobradovic08
- Add EdgeCore ECS4110-28T Support (#10525) - soto2080
- Support VIOS which use a different string: (#10623) - fbourqui
- Added CISCO-ENTITY-QFP-MIB MIB (#10621) - pobradovic08
- AeroHive OS Wirelless Noise Floor Fix (#10608) - jozefrebjak
- Skip notPresent ports from state sensors (#10545) - Rosiak
- Eltek eNexus sensor improvements (#10591) - vitalisator
- Add more Vigor series device support (#10562) - jasoncheng7115
- Fix Ericsson MINI LINK wifi sensors (#10566) - erotel
- Added Additional support for Dell CMC (#10571) - takenalias
- Added basic state details for Infoblox NIOS (#10572) - FTBZ
Webui
- Device overview - group utilization per processor type (#10626) - pobradovic08
- Fix LibreNMS Logo SVG missing i sometimes (#10632) - YisroelTech
- Allow OS to define config highlighting (pfSense) (#10392) - brownowski
- List ungrouped devices on group management page (#10527) - SourceDoctor
- Fix wrong formatting of runtime sensor value (#10606) - vitalisator
- Fix missing to-parameter in dashboard graph widget link (#10600) - feuerrot
- Use more distinct HTML div element ids when listing alerts in tables (#10587) - dsgagi
- Move Authlog to Laravel (#10559) - Jellyfrog
Graphs
- Storage RRD - descriptionlength fix - percent column fix (#10607) - SourceDoctor
- Extended ‘port previous’ graphs (#10556) - SniperVegeta
Alerting
- Add procedure URL to alert templates (#10609) - seros1521
- Alert template clean up “\r\n\n” (#10541) - bestlong
- Add LINE Notify Alert Transport. (#10495) - bestlong
- Catch exceptions generated by alert transports (#10565) - lfkeitel
Discovery
- Do not discover dbm sensors on shutdown ports (#10610) - vitalisator
- Sensors sometime not clean up (#10611) - vitalisator
- Fixed foreach loop throwing errors when no vlans present (#10599) - nistorj
Polling
- Add support for per-OS SNMP max repeaters configuration file setting. (#10628) - nwautomator
- MPLS only poll if records exist (#10523) - murrant
Bug
- Remove ambiguity in Component filter query (#10638) - pobradovic08
- Replaced description by ifAlias to fix the sort on Description (#10633) - dGs-
- Fix creating device groups issue (#10521) - murrant
- Web UI: Fix port URLs on minimaps page (#10619) - pobradovic08
- Fix timeout typo in apiclients (#10615) - Jellyfrog
- Add index to notifications_attribs to resolve slow page load on MySQL 5.7 (#10589) - wilreichert
- Geographical map fix for “normal user” (#10590) - SourceDoctor
- Graylog fix query with multiple items (#10583) - rsys-dev
Documentation
- Add example for EdgeOs Ubiquiti (#10639) - Cormoran96
- Asterisk Doc Improvements (#10631) - CameronMunroe
- Dispatcher Service: Documentation Typo (#10620) - Derova
- Improve CentOS 7 install instructions (#10477) - deajan
- More documentation clean up (#10577) - VVelox
- Fix documentation TOC (#10580) - murrant
- Added linear prediction how-to (#10581) - hanserasmus
- Updated Fast-Ping-Check documentation for distributed pollers (#10575) - garysteers
Translation
- French translation minor update (#10640) - PipoCanaja
- Adding german language support (#10584) - SourceDoctor
- Add Graylog severity translation (#10593) - jasoncheng7115
- Modify the syslog widget can be translate (#10594) - jasoncheng7115
- French translation (#10586) - Bounzz
- Update zh-TW.json for authlog page (#10579) - jasoncheng7115
- Update fr.json (#10578) - Bounzz
