V1.60 Release + Changelog (January 2020)
A big thank you to the following 32 contributors this last month:
Thanks to maintainers that helped merge pull requests this month:
Feature
Device
Webui
Snmp Traps
Applications
Alerting
  • Remove also Associations by deleting Scheduled Maintenance (#11093) - SourceDoctor
  • Remove redundant data from Alert fallback detail (#11081) - SourceDoctor
  • Cisco Spark Do not strip tags when markdown is in use. (#11075) - xorrkaz
  • Added fix for escaping underscore while using Markdown (#11070) - SpaceDump
  • Add alert rule option to invert devices and groups “map to” list (#11038) - louis-oui
  • Do not update alert timestamp when updating a triggered alert (#10907) - louis-oui
Billing
Discovery
  • Don’t overwrite real port ids with zeros in the FDB (#11041) - cjwbath
  • Add bad_ifoperstatus for filtering interfaces having a status for example ‘notPresent’ (#10977) - LEV82
Polling
Bug
Refactor
Cleanup
Documentation
  • SELinux fix for syslog-ng with LibreNMS on Centos (#11014) - dagbdagb
Translation
