LibreNMS version 1.62 has been released!
We thank each and every of the 34 different contributors to LibreNMS this month. Make sure you thank them for their time and effort
If you would like help with LibreNMS in any way, let us know in Discord .
There was a nice feature added to show links on the geographical map and a change to allow links to be collected even when auto-discover is disabled. There was some under the hood changes to our datastore code that should allow for future improvements and also added tag support for OpenTSDB.
Work on the Web UI to refactor it to take advantage of Laravel is underway. There should be some changes in each release for some time and this is no exception. The most prominent page ported is the pollers page.
There have been a few more settings added to the Web UI, if you would like to help out, check out the documentation.
19 devices have new or updated support.
You can find our change log here .
As usual there are some great changes pending for next month. You can checkout the Pull Requests on GitHub and give feedback on them to help them get merged.
As always, happy monitoring.
