Vlans discovery issue
Actually librenms found my switch’s vlans, like that :
Capture
But, I have the same switch, with the same dependencies/model on my network,
Librenms doesn’t find the vlans :
Capture2
do you know why ? :disappointed_relieved:
./validate.php
LibreNMS 1.51-53-g9d56593a2
DB Schema 2019_02_10_220000_add_dates_to_fdb (132)
PHP 7.2.15-0ubuntu0.18.04.2
MySQL 10.1.38-MariaDB-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.8.5
[WARN] Your install is over 24 hours out of date, last update: Wed, 15 May 2019 03:13:53 +0000
Thank you
Use https://docs.librenms.org/Support/Device-Troubleshooting/
and pastebin the capture of poller and discovery.
discovery
LibreNMS Discovery
Version info:
Commit SHA: 9d56593a2c9a13dbfd5d481e6ba1a0b2a17bd8d4
Commit Date: 1557890033
DB Schema: 2019_02_10_220000_add_dates_to_fdb (132)
PHP: 7.2.15-0ubuntu0.18.04.2
MySQL: 10.1.38-MariaDB-0ubuntu0.18.04.1
RRDTool: 1.7.0
SNMP: NET-SNMP 5.7.3
10.2.30.12 40 comnet
Load disco module core
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQn’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘sysName.0’ ‘sysObjectID.0’ ‘sysDescr.0’]
Runtime for discovery module ‘core’: 0.0090 seconds with 1088 bytes
SNMP: [2/0.02s] MySQL: [4/0.00s] RRD: [0/0.00s]
Unload disco module core
Load disco module os
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovq’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysDescr.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovqn’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysObjectID.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.1166.1.621.14.2.0’]
OS: Switch Comnet (comnet)
Runtime for discovery module ‘os’: 0.0300 seconds with 50528 bytes
SNMP: [3/0.03s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
Load disco module ports
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifDescr’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifName’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifAlias’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifType’]
Runtime for discovery module ‘ports’: 0.0440 seconds with 4032 bytes
SNMP: [4/0.04s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports
Load disco module ports-stack
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifStackStatus’]
Runtime for discovery module ‘ports-stack’: 0.0110 seconds with 1736 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports-stack
Load disco module entity-physical
Caching OIDs: entPhysicalEntrySNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘ENTITY-MIB:CISCO-ENTITY-VENDORTYPE-OID-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘entPhysicalEntry’]
Runtime for discovery module ‘entity-physical’: 0.0240 seconds with 6232 bytes
SNMP: [1/0.02s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module entity-physical
Module [ entity-state ] disabled on os.
Load disco module processors
Host Resources: SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘HOST-RESOURCES-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘hrProcessorLoad’]
UCD Resources: SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovq’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.2021.11.11.0’]
Runtime for discovery module ‘processors’: 0.0260 seconds with 66224 bytes
SNMP: [2/0.02s] MySQL: [5/0.00s] RRD: [0/0.00s]
Unload disco module processors
Load disco module mempools
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUseQ’ ‘-m’ ‘DELL-NETWORKING-CHASSIS-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet:/opt/librenms/mibs/dell’ ‘udp:HOSTNAME:161’ ‘dellNetCpuUtilTable’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUseQ’ ‘-m’ ‘DELL-NETWORKING-CHASSIS-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet:/opt/librenms/mibs/dell’ ‘udp:HOSTNAME:161’ ‘DellNetProcessorEntry’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘NETSWITCH-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet:/opt/librenms/mibs/hp’ ‘udp:HOSTNAME:161’ ‘hpLocal’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘NETSWITCH-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet:/opt/librenms/mibs/hp’ ‘udp:HOSTNAME:161’ ‘hpGlobal’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES:NetWare-Host-Ext-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘hrStorageEntry’]
Runtime for discovery module ‘mempools’: 0.1010 seconds with 65752 bytes
SNMP: [5/0.10s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module mempools
Load disco module cisco-vrf-lite
Runtime for discovery module ‘cisco-vrf-lite’: 0.0000 seconds with 2624 bytes
Unload disco module cisco-vrf-lite
Module [ cisco-mac-accounting ] disabled on os.
Module [ cisco-pw ] disabled on os.
Module [ vrf ] disabled on os.
Module [ cisco-cef ] disabled on os.
Module [ cisco-sla ] disabled on os.
Module [ cisco-cbqos ] disabled on os.
Module [ cisco-otv ] disabled on os.
Load disco module ipv4-addresses
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Osq’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipAdEntIfIndex’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipAdEntNetMask.’]
Runtime for discovery module ‘ipv4-addresses’: 0.0240 seconds with 37128 bytes
SNMP: [2/0.02s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ipv4-addresses
Load disco module ipv6-addresses
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Osq’ ‘-Ln’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipAddressIfIndex.ipv6’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OsqnU’ ‘-Ln’ ‘-m’ ‘IPV6-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipv6AddrPfxLength’]
Runtime for discovery module ‘ipv6-addresses’: 0.0300 seconds with 3312 bytes
SNMP: [2/0.03s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ipv6-addresses
Module [ route ] disabled on os.
Load disco module sensors
ENTITY-SENSOR: Caching OIDs: entPhysicalDescrSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘ENTITY-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘entPhysicalDescr’]
Airflow:
Current:
Charge:
Dbm:
Fanspeed:
Frequency:
Humidity:
Load:
Power:
Power_consumed:
Power_factor:
Runtime:
Signal:
State:
Count:
Temperature:
Voltage:
Snr:
Pressure:
Cooling:
Delay:
Quality_factor:
Chromatic_dispersion:
Ber:
Eer:
Waterflow:
Runtime for discovery module ‘sensors’: 0.0490 seconds with 48328 bytes
SNMP: [1/0.01s] MySQL: [31/0.03s] RRD: [0/0.00s]
Unload disco module sensors
Load disco module storage
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘DATA-DOMAIN-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet:/opt/librenms/mibs/datadomain’ ‘udp:HOSTNAME:161’ ‘fileSystemSpaceTable’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-SNMP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dskTable’]
Runtime for discovery module ‘storage’: 0.0670 seconds with 9296 bytes
SNMP: [3/0.07s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module storage
Load disco module hr-device
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘hrDeviceEntry’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘hrProcessorEntry’]
Runtime for discovery module ‘hr-device’: 0.0240 seconds with 3696 bytes
Unload disco module hr-device
Load disco module discovery-protocols
CISCO-CDP-MIB: SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘CISCO-CDP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘cdpCache’]
LLDP-MIB: SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘LLDP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘lldpRemTable’]
Runtime for discovery module ‘discovery-protocols’: 0.0340 seconds with 6104 bytes
SNMP: [0/0.00s] MySQL: [2/0.00s] RRD: [0/0.00s]
Unload disco module discovery-protocols
Load disco module arp-table
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipNetToPhysicalPhysAddress’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipNetToMediaPhysAddress’]
Runtime for discovery module ‘arp-table’: 0.0270 seconds with 2200 bytes
Unload disco module arp-table
Load disco module discovery-arp
Runtime for discovery module ‘discovery-arp’: 0.0000 seconds with 1680 bytes
Unload disco module discovery-arp
Module [ junose-atm-vp ] disabled on os.
Load disco module bgp-peers
SNMP[‘/usr/bin/snmpgetnext’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqvn’ ‘-m’ ‘BGP4-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘bgpLocalAs’]
No BGP on host
Runtime for discovery module ‘bgp-peers’: 0.0110 seconds with 6504 bytes
SNMP: [1/0.01s] MySQL: [2/0.00s] RRD: [0/0.00s]
Unload disco module bgp-peers
Load disco module vlans
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘BRIDGE-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot1dBasePortIfIndex’]
IEEE8021-Q-BRIDGE-MIB VLANs: SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘IEEE8021-Q-BRIDGE-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot1qVlanVersionNumber.0’]
Runtime for discovery module ‘vlans’: 0.0320 seconds with 9096 bytes
Unload disco module vlans
Module [ vmware-vminfo ] disabled on os.
Module [ libvirt-vminfo ] disabled on os.
Module [ toner ] disabled on os.
Load disco module ucd-diskio
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-DISKIO-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘diskIOEntry’]
Runtime for discovery module ‘ucd-diskio’: 0.0200 seconds with 3112 bytes
Unload disco module ucd-diskio
Module [ applications ] disabled on os.
Load disco module services
Runtime for discovery module ‘services’: 0.0000 seconds with 296 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module services
Load disco module stp
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘RSTP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot1dStpProtocolSpecification.0’]
Runtime for discovery module ‘stp’: 0.0110 seconds with 5744 bytes
SNMP: [1/0.01s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module stp
Load disco module ntp
Runtime for discovery module ‘ntp’: 9.2980 seconds with 232 bytes
Unload disco module ntp
Module [ loadbalancers ] disabled on os.
Module [ mef ] disabled on os.
Load disco module wireless
Runtime for discovery module ‘wireless’: 0.0080 seconds with 125392 bytes
SNMP: [0/0.00s] MySQL: [19/0.01s] RRD: [0/0.00s]
Unload disco module wireless
Load disco module fdb-table
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘Q-BRIDGE-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot1qTpFdbPort’]
Q-BRIDGE-MIB:SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUsetX’ ‘-m’ ‘BRIDGE-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot1dBasePortIfIndex’]
Runtime for discovery module ‘fdb-table’: 0.1420 seconds with 67384 bytes
SNMP: [0/0.00s] MySQL: [9/0.02s] RRD: [0/0.00s]
Unload disco module fdb-table
SNMP[‘/usr/bin/snmptranslate’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘-IR’ ‘-m’ ‘all’ ‘.1.3.6.1.4.1.32298.2.2.27’]
Discovered in 1.976 seconds
SNMP [32/0.46s]: Get[9/0.10s] Getnext[1/0.01s] Walk[22/0.35s]
MySQL [91/0.09s]: Cell[2/0.00s] Row[9/0.01s] Rows[68/0.05s] Column[2/0.00s] Update[3/0.02s] Insert[2/0.01s] Delete[5/0.00s]
RRD [0/0.00s]: Update[0/0.00s] Create [0/0.00s] Other[0/0.00s]
poller
LibreNMS Poller
Version info:
RRDTool: 1.7.0
Starting polling run:
Hostname: 10.2.30.12
Device ID: 40
OS: comnet
Load poller module core
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQnUt’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘sysUpTime.0’ ‘sysLocation.0’ ‘sysContact.0’ ‘sysName.0’ ‘sysObjectID.0’ ‘sysDescr.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQnUst’ ‘-m’ ‘HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘snmpEngineTime.0’ ‘hrSystemUptime.0’]
RRD[last 10.2.30.12/uptime.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/uptime.rrd N:886217 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Uptime: 10 days 6 hours 10 minutes 17 seconds
Runtime for poller module ‘core’: 0.0512 seconds with 102736 bytes
SNMP: [2/0.05s] MySQL: [0/0.00s] RRD: [1/0.00s]
Unload poller module core
RRD[last 10.2.30.12/poller-perf-core.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-core.rrd N:0.051222801208496 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Module [ unix-agent ] disabled globally.
Load poller module os
Generic :frowning:
Hardware:
Version:
Features:
Serial:
Runtime for poller module ‘os’: 0.0012 seconds with 49704 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [1/0.00s]
Unload poller module os
RRD[last 10.2.30.12/poller-perf-os.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-os.rrd N:0.0011770725250244 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module ipmi
Runtime for poller module ‘ipmi’: 0.0009 seconds with 2488 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [1/0.00s]
Unload poller module ipmi
RRD[last 10.2.30.12/poller-perf-ipmi.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-ipmi.rrd N:0.00090408325195312 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module sensors
Runtime for poller module ‘sensors’: 0.0005 seconds with 1464 bytes
Unload poller module sensors
RRD[last 10.2.30.12/poller-perf-sensors.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-sensors.rrd N:0.00052309036254883 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module processors
Runtime for poller module ‘processors’: 0.0030 seconds with 91280 bytes
Unload poller module processors
RRD[last 10.2.30.12/poller-perf-processors.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-processors.rrd N:0.0030319690704346 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module mempools
Runtime for poller module ‘mempools’: 0.0009 seconds with 1720 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [1/0.01s]
Unload poller module mempools
RRD[last 10.2.30.12/poller-perf-mempools.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-mempools.rrd N:0.00092101097106934 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module storage
Runtime for poller module ‘storage’: 0.0009 seconds with 1704 bytes
Unload poller module storage
RRD[last 10.2.30.12/poller-perf-storage.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-storage.rrd N:0.00086688995361328 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module netstats
ICMPSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘icmp’]
IPSNMP[‘/usr/bin/snmpgetnext’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipForwDatagrams’ ‘ipInDelivers’ ‘ipInReceives’ ‘ipOutRequests’ ‘ipInDiscards’ ‘ipOutDiscards’ ‘ipOutNoRoutes’ ‘ipReasmReqds’ ‘ipReasmOKs’ ‘ipReasmFails’ ‘ipFragOKs’ ‘ipFragFails’ ‘ipFragCreates’ ‘ipInUnknownProtos’ ‘ipInHdrErrors’ ‘ipInAddrErrors’]
IP-FORWARDSNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘IP-FORWARD-MIB::ipCidrRouteNumber.0’]
SNMPSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘snmp’]
RRD[last 10.2.30.12/netstats-snmp.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/netstats-snmp.rrd N:53174:51022:0:0:0:0:0:0:0:0:0:90340:0:21992:8547:0:0:0:0:0:0:2160:0:0:0:51015:9:U:U --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled] TCPSNMP[‘/usr/bin/snmpgetnext’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘TCP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘tcpActiveOpens’ ‘tcpPassiveOpens’ ‘tcpAttemptFails’ ‘tcpEstabResets’ ‘tcpCurrEstab’ ‘tcpInSegs’ ‘tcpOutSegs’ ‘tcpRetransSegs’ ‘tcpInErrs’ ‘tcpOutRsts’]
TCPHCSNMP[‘/usr/bin/snmpgetnext’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘TCP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘tcpHCInSegs.0’ ‘tcpHCOutSegs.0’]
RRD[last 10.2.30.12/netstats-tcp.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/netstats-tcp.rrd N:0:14:0:5:4294967263:375:322:0:9:9 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled] UDPSNMP[‘/usr/bin/snmpgetnext’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UDP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘udpInDatagrams’ ‘udpOutDatagrams’ ‘udpInErrors’ ‘udpNoPorts’]
RRD[last 10.2.30.12/netstats-udp.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/netstats-udp.rrd N:53426:54113:29:0 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Runtime for poller module ‘netstats’: 0.1488 seconds with 3360 bytes
SNMP: [7/0.14s] MySQL: [0/0.00s] RRD: [4/0.00s]
Unload poller module netstats
RRD[last 10.2.30.12/poller-perf-netstats.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-netstats.rrd N:0.14876103401184 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module hr-mib
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQs’ ‘-m’ ‘HOST-RESOURCES-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘hrSystemProcesses.0’ ‘hrSystemNumUsers.0’]
Runtime for poller module ‘hr-mib’: 0.0266 seconds with 1520 bytes
SNMP: [1/0.03s] MySQL: [0/0.00s] RRD: [1/0.00s]
Unload poller module hr-mib
RRD[last 10.2.30.12/poller-perf-hr-mib.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-hr-mib.rrd N:0.02659797668457 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module ucd-mib
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-SNMP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘systemStats’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-SNMP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘memTotalSwap.0’ ‘memAvailSwap.0’ ‘memTotalReal.0’ ‘memAvailReal.0’ ‘memTotalFree.0’ ‘memShared.0’ ‘memBuffer.0’ ‘memCached.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘UCD-SNMP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘laLoadInt.1’ ‘laLoadInt.2’ ‘laLoadInt.3’]
Runtime for poller module ‘ucd-mib’: 0.0907 seconds with 2544 bytes
SNMP: [3/0.09s] MySQL: [0/0.00s] RRD: [1/0.00s]
Unload poller module ucd-mib
RRD[last 10.2.30.12/poller-perf-ucd-mib.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-ucd-mib.rrd N:0.090691089630127 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module ipSystemStats
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IP-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ipSystemStats’]
Runtime for poller module ‘ipSystemStats’: 0.0366 seconds with 1888 bytes
SNMP: [1/0.04s] MySQL: [0/0.00s] RRD: [1/0.00s]
Unload poller module ipSystemStats
RRD[last 10.2.30.12/poller-perf-ipSystemStats.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-ipSystemStats.rrd N:0.03664493560791 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module ports
Caching Oids: Full ports polling SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifXEntry’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUst’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘ifEntry’]
dot3StatsDuplexStatusSNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘EtherLike-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot3StatsDuplexStatus’]
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQUs’ ‘-m’ ‘Q-BRIDGE-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/comnet’ ‘udp:HOSTNAME:161’ ‘dot1qPvid’]
Runtime for poller module ‘ports’: 0.0549 seconds with 41424 bytes
SNMP: [4/0.05s] MySQL: [1/0.00s] RRD: [1/0.00s]
Unload poller module ports
RRD[last 10.2.30.12/poller-perf-ports.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-ports.rrd N:0.054924011230469 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module bgp-peers
Runtime for poller module ‘bgp-peers’: 0.0009 seconds with 11504 bytes
Unload poller module bgp-peers
RRD[last 10.2.30.12/poller-perf-bgp-peers.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-bgp-peers.rrd N:0.0009160041809082 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Module [ junose-atm-vp ] disabled globally.
Module [ toner ] disabled globally.
Load poller module ucd-diskio
Runtime for poller module ‘ucd-diskio’: 0.0003 seconds with 1824 bytes
Unload poller module ucd-diskio
RRD[last 10.2.30.12/poller-perf-ucd-diskio.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-ucd-diskio.rrd N:0.00031709671020508 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Module [ wifi ] disabled globally.
Load poller module wireless
Runtime for poller module ‘wireless’: 0.0010 seconds with 102264 bytes
Unload poller module wireless
RRD[last 10.2.30.12/poller-perf-wireless.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-wireless.rrd N:0.00096893310546875 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Module [ ospf ] disabled globally.
Module [ cisco-ipsec-flow-monitor ] disabled globally.
Module [ cisco-remote-access-monitor ] disabled globally.
Module [ cisco-cef ] disabled globally.
Module [ cisco-sla ] disabled globally.
Module [ cisco-mac-accounting ] disabled globally.
Module [ cipsec-tunnels ] disabled globally.
Module [ cisco-ace-loadbalancer ] disabled globally.
Module [ cisco-ace-serverfarms ] disabled globally.
Module [ cisco-asa-firewall ] disabled globally.
Module [ cisco-voice ] disabled globally.
Module [ cisco-cbqos ] disabled globally.
Module [ cisco-otv ] disabled globally.
Module [ cisco-vpdn ] disabled globally.
Module [ nac ] disabled globally.
Module [ netscaler-vsvr ] disabled globally.
Module [ aruba-controller ] disabled globally.
Load poller module entity-physical
Runtime for poller module ‘entity-physical’: 0.0003 seconds with 1928 bytes
Unload poller module entity-physical
RRD[last 10.2.30.12/poller-perf-entity-physical.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-entity-physical.rrd N:0.0002901554107666 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Module [ entity-state ] disabled globally.
Load poller module applications
Runtime for poller module ‘applications’: 0.0002 seconds with 1472 bytes
Unload poller module applications
RRD[last 10.2.30.12/poller-perf-applications.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-applications.rrd N:0.0001990795135498 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module mib
MIB: polling
Runtime for poller module ‘mib’: 0.0003 seconds with 1232 bytes
SNMP: [0/0.00s] MySQL: [2/0.00s] RRD: [1/0.00s]
Unload poller module mib
RRD[last 10.2.30.12/poller-perf-mib.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-mib.rrd N:0.00034499168395996 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module stp
Runtime for poller module ‘stp’: 0.0094 seconds with -7800 bytes
SNMP: [1/0.01s] MySQL: [1/0.00s] RRD: [1/0.00s]
Unload poller module stp
RRD[last 10.2.30.12/poller-perf-stp.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-stp.rrd N:0.009368896484375 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Load poller module ntp
Runtime for poller module ‘ntp’: 0.0001 seconds with 320 bytes
Unload poller module ntp
RRD[last 10.2.30.12/poller-perf-ntp.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf-ntp.rrd N:6.8902969360352E-5 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]Module [ loadbalancers ] disabled globally.
Module [ mef ] disabled globally.
Enabling graphs: uptime netstat_snmp netstat_snmp_pkt netstat_tcp netstat_udp
RRD[last 10.2.30.12/ping-perf.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/ping-perf.rrd N:1.15 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]RRD[last 10.2.30.12/poller-perf.rrd --daemon unix:/var/run/rrdcached.sock]
RRD[update 10.2.30.12/poller-perf.rrd N:1.486 --daemon unix:/var/run/rrdcached.sock]
[RRD Disabled]
Polled in 1.486 seconds
Start Alerts
Rule #1 (Devices up/down): Status: NOCHG
Rule #2 (Device rebooted): Status: NOCHG
Rule #3 (BGP Session down): Status: NOCHG
Rule #4 (BGP Session established): Status: NOCHG
Rule #5 (Port status up/down): Status: NOCHG
Rule #6 (Port utilisation over threshold): Status: NOCHG
Rule #7 (Sensor over limit - Check Device Health Settings): Status: NOCHG
Rule #8 (Sensor under limit - Check Device Health Settings): Status: NOCHG
Rule #9 (Service up/down): Status: NOCHG
Rule #10 (Wireless Sensor over limit): Status: NOCHG
Rule #11 (Wireless Sensor under limit): Status: NOCHG
Rule #12 (State Sensor Critical): Status: NOCHG
End Alerts
SNMP [20/0.42s]: Get[8/0.17s] Getnext[4/0.08s] Walk[8/0.17s]
MySQL [34/0.07s]: Cell[14/0.01s] Row[-12/-0.01s] Rows[28/0.03s] Column[1/0.00s] Update[1/0.01s] Insert[2/0.03s] Delete[0/0.00s]
RRD [26/0.01s]: Update[0/0.00s] Create [0/0.00s] Other[26/0.01s]
