hi there,
i have the same exact problem than:
from the editor, my maps are read only.
but i can modify the conf files with putty. (which is a bit tedious)
i tried the given solution, but the problem remains.
any clue?
thanks
| Component |
Version |
| LibreNMS |
1.57-94-g1ab645c75 |
| DB Schema |
2019_04_22_220000_update_route_table (147) |
| PHP |
7.2.24-0ubuntu0.18.04.1 |
| MySQL |
10.1.43-MariaDB-0ubuntu0.18.04.1 |
| RRDTool |
1.7.0 |
| SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.5
Dejan
2
Did you ever solve this?
I have exact same problem. Cannot edit files (read-only) Permissions are as recommended by documentation
Dejan
3
What i did was to change ownership of the file .conf as
-rw-r–r-- 1 www-data librenms
Now i can both edit and view
