Is it possible to add some sort of histogram for the Weathermap plugin, so that you can slide a scrollbar to see the changes on the Weathermap based on time (taken from previous snapshots)?
I understand the alternative is to look at the throughput graphs via LibreNMS, however it would be nice to see this from a Weathermap perspective as well.
It creates the GIF, and stores it per day, so you can select it in the web calendar. I used this GIF player aswell so it’s easy to scroll through the timeline gif-player demos
I’m very happy with the results, let me know if you try it
