I cant acces webui. I am using ubuntu 18.0.4
here is the log
Stack trace:
#0 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(2, ‘file_put_conten…’, ‘/opt/librenms/v…’, 122, Array)
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(122): file_put_contents(‘/opt/librenms/s…’, ‘1536734944b:1;’, 2)
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cache/FileStore.php(66): Illuminate\Filesystem\Filesystem->put(‘/opt/librenms/s…’, ‘1536734944b:1;’, true)
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cache/Repository.php(175): Illuminate\Cache\FileStore->put(‘checks_popup_ti…’, true, 5)
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cache/CacheManager.php(305): Illuminate\Cache\Repository->put(‘checks_popup_ti…’, true, 5)
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(221): Illuminate\Cache\CacheManager->__call(‘put’, Array)
#6 /opt/librenms/app/Checks.php(159): Illuminate\Support\Facades\Facade::__callStatic(‘put’, Array)
#7 /opt/librenms/app/Http/Controllers/LegacyController.php(11): App\Checks::postAuth()
#8 [internal function]: App\Http\Controllers\LegacyController->index(‘’)
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(55): call_user_func_array(Array, Array)
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(44): Illuminate\Routing\Controller->callAction(‘index’, Array)
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(203): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\LegacyController), ‘index’)
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(160): Illuminate\Routing\Route->runController()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(572): Illuminate\Routing\Route->run()
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\Routing\Router->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#15 /opt/librenms/app/Http/Middleware/VerifyTwoFactor.php(38): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): App\Http\Middleware\VerifyTwoFactor->handle(Object(Illuminate\Http\Request), Object(Closure))
#17 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#21 /opt/librenms/app/Http/Middleware/LegacyExternalAuth.php(46): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): App\Http\Middleware\LegacyExternalAuth->handle(Object(Illuminate\Http\Request), Object(Closure))
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(65): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#25 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/AuthenticateSession.php(54): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Session\Middleware\AuthenticateSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(43): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Auth\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure))
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#35 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#42 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(59): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#43 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#44 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#45 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#46 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(574): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#47 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(533): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#48 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(511): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#49 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#50 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http{closure}(Object(Illuminate\Http\Request))
#51 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#52 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#53 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#54 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#55 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#56 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#57 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#58 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#59 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#60 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(46): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#61 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(148): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure))
#62 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#63 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#64 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(151): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#65 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(116): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#66 /opt/librenms/html/index.php(53): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#67 {main}
[2018-09-12 08:44:04] production.ERROR: ErrorException: file_put_contents(/opt/librenms/storage/framework/sessions/LTGtZenw3hysRds2tgfGVnQs0WlHYyWFyL4NLHfE): failed to open stream: Permission denied in /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php:122
Stack trace:
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(122): file_put_contents(‘/opt/librenms/s…’, ‘a:8:{s:6:"_toke…’, 2)
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/FileSessionHandler.php(83): Illuminate\Filesystem\Filesystem->put(‘/opt/librenms/s…’, ‘a:8:{s:6:"_toke…’, true)
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Store.php(128): Illuminate\Session\FileSessionHandler->write(‘LTGtZenw3hysRds…’, ‘a:8:{s:6:"_toke…’)
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(88): Illuminate\Session\Store->save()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(218): Illuminate\Session\Middleware\StartSession->terminate(Object(Illuminate\Http\Request), Object(Illuminate\Http\Response))
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(189): Illuminate\Foundation\Http\Kernel->terminateMiddleware(Object(Illuminate\Http\Request), Object(Illuminate\Http\Response))
#7 /opt/librenms/html/index.php(58): Illuminate\Foundation\Http\Kernel->terminate(Object(Illuminate\Http\Request), Object(Illuminate\Http\Response))
#8 {main}
[2018-09-12 08:44:04] production.ERROR: ErrorException: file_put_contents(/opt/librenms/storage/framework/cache/data/a2/e3/a2e33a1054e69b8e67fdec79e8e92f7ef1097c07): failed to open stream: Permission denied in /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php:122
Stack trace:
#67 {main}
Stack trace:
#8 {main}
when i trying to update
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB
it is on cleaning up DB very long time and nothing happening
here is the validate.php
| LibreNMS | 1.43-50-ge8cf6bb38 |
| DB Schema | 267 |
| PHP | 7.2.7-0ubuntu0.18.04.2 |
| MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
