23.8.0
(2023-08-19)
A big thank you to the following 32 contributors this last month:
- murrant (31)
- VVelox (5)
- Jellyfrog (4)
- electrocret (4)
- santiag0z (3)
- laf (3)
- viptampa (3)
- arjenz (2)
- knpo (1)
- WhiteyDude (1)
- jacobw (1)
- jepke (1)
- sjtarik (1)
- pjordanovic (1)
- Schouwenburg (1)
- eggbeater98 (1)
- i4networks (1)
- fbourqui (1)
- hirose003 (1)
- richard-ririe (1)
- robje (1)
- peejaychilds (1)
- bonzo81 (1)
- slashdoom (1)
- eskyuu (1)
- j796160836 (1)
- TheMysteriousX (1)
- VirTechSystems (1)
- fufroma (1)
- zappiehost (1)
- jgelinas (1)
- mwobst (1)
- murrant (26)
- Jellyfrog (25)
- electrocret (23)
- PipoCanaja (3)
- laf (2)
- VVelox (2)
- ottorei (1)
- streamthing (1)
Feature
- Add FDB table vendor search drop down (#15072) - bonzo81
- Port_error_perc macro (#15016) - electrocret
Security
- Fix unsanitized input injection (#15184) - murrant
- Fix some xss injection for sysLocation and some other fields (#15183) - murrant
Device
- Fix version comparison for RouterOS (#15227) - knpo
- Netscaler, don’t use 0 divisor (#15204) - murrant
- Update Alpine Linux logos to SVG (#15185) - murrant
- APC new sensors and fix (#15179) - jepke
- Add SHARP BP series of devices (#15169) - pjordanovic
- Fix Timos SAR Cellular RSRP and RSSI sensors (#15163) - Schouwenburg
- Update bgp-peers.inc.php for timos (#15154) - i4networks
- Fortigate ipv6 ipsec (#15150) - fbourqui
- Add Calix E7 (EXA) PON port sensors (#15145) - murrant
- Add os check in discovery for aix/freenas storage and cisco cdp (#15104) - peejaychilds
- Add VLAN Discovery for arubaos-cx (#15055) - slashdoom
- Openmanage enterprise modular (#14408) - jgelinas
Webui
- Fixed CSS error causing generic image widgets not to do height correctly (#15220) - WhiteyDude
- Fix error when there is an untranslated sensor type (#15176) - murrant
- Fix select2 search field focus (#15171) - murrant
- Update text color in dark.css (#15155) - eggbeater98
Alerting
- Discord Transport user configurable embed fields (#15068) - murrant
- Implement LINE Messaging API (#14867) - j796160836
Graphs
- Fix Memmory spelling (#15231) - arjenz
- Add generic stats graph munging support and make uptime display as days again (#15097) - VVelox
Applications
- Add the Mojo CAPE Submit app (#15140) - VVelox
- Logsize monitoring for LibreNMS (#15137) - VVelox
- Update SMART monitoring to the use JSON (#15132) - VVelox
- Add a flag for adding app data to tests generated via scripts/json-app-tool.php (#15080) - VVelox
- Add BIRD2 BGP Peers application support (#14466) - zappiehost
Billing
- Fixed a zero value data insertion for billing (#15194) - laf
- Updated poll-billing.php to only query for data via snmp when the device and port are both up (#15164) - laf
- Added basic support for distributing billing (#15156) - laf
Api
- Add API endpoint to get service graphs (#15138) - richard-ririe
- API get_location (#14779) - VirTechSystems
Discovery
Polling
- Allow dispatcher service master timeout to be set (#15161) - murrant
- Fix fping 4.0+ prefers IPv6 (#14825) - TheMysteriousX
- Add module support for wrapper script calls (#14055) - mwobst
Authentication
Bug
- Print a useful error if logfile is not writable (#15233) - murrant
- Make the installer use the schema dump (#15211) - Jellyfrog
- Change leaflet.default_zoom to Float (#15207) - electrocret
- Handle empty dbSchema table (#15198) - murrant
- Fix timezone controller bad return (#15191) - murrant
- Graylog API properly throw errors (#15188) - murrant
- Fixing the mac/vendor database download from wireshark, updated file … (#15175) - sjtarik
- Fix alert.macros.rule (#15172) - electrocret
- Miscellaneous fixes (#15162) - murrant
- Change display query of list_devices to pattern match (#15147) - hirose003
- Change rrd_prune find command to exlcude
.gitignore(#15134) - robje - Apply service templates on a per-device basis (#15024) - eskyuu
- RFC1628 - Force cast on some values before doing arithmetic (#14613) - fufroma
Refactor
Cleanup
Documentation
- [DOC] Added social links in footer (#15195) - santiag0z
- OS discovery clarification (#15182) - murrant
- [DOC] Remove ~$ from BIND9 code block aka named (#15181) - santiag0z
- Fix settings titles in dark mode (#15174) - murrant
- Update Routeros.md (#15165) - viptampa
- Update Routeros.md (#15160) - viptampa
- RouterOS Vlan agent script clarification (#15158) - viptampa
- Fix bad link in Install-LibreNMS.md (#15152) - arjenz
Tests
Misc
Internal Features
- Set mibs explicitly in SnmpQuery (#15199) - murrant
- Editor yaml indent fine tuning (#15189) - murrant
